06.09.2008, 09:29 PM
Take a set of stampede rear or front posts - Cut off top 20mm or so.
They are round posts so to mount easier against tower dremel a flat surface on both posts.
Live up against tower at desired height - Drill 2,5mm hole through post (through mount hole on tower).
Affix with 3mm machine screw and locknut
GO-RIDE.com
06.09.2008, 09:46 PM
Put them on the back side of the shock tower. I broke a couple mounted in the stock position on the front of the shock tower, but it's been months without breaking them mounted on the back side. You will probably have to drill new body mount holes.
E-8ight - Tekin RX8 2000kv/4S
