kyosho501x
kyosho501x's Avatar
06.17.2008, 09:56 PM
should i use the reinforced bit or the unreinforced?
hyper 8- workin on conversion
tc3_racer_001
tc3_racer_001's Avatar
06.18.2008, 02:36 AM
get a lighter and heat up the screw, this will melt the locktight. then unscrew it quickly. i try to avoid cutting anything as i always screw it up lol... but its pretty clean. and yours doesnt have that pesky mount to deal with!! GRRR.. urs will be finished before mine. in regards to the body. im a good driver and ill never flip
ill just not cut as much off and mount it higher that normal. shouldnt matter if i flip it as they are alloy cells and a small bump wont hurt them will it?? a123 7s would be ok on the MMM but nothing more and you would get away with (albeit short) amp draw requirements)
BTW: do you recon i could steal a hyper 8 diff brace and diff mount? if i could i would avoid all these issues!! hooray!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
othello
HV basher
06.18.2008, 04:18 AM
If you flip your centerdiff by 180° your motor could be placed on the opposite side of your steering servo (front left). This way you would most likely have enough space to place 2 4s1p A123 packs in sidebyside config behind the center diff (giving you a well balanced buggy). With 4s2p A123 a 2200kv motor will rev up to 24000-26000rpm under load. With a somewhat bigger pinion you should be able to gear it for 40mph. A123 cells in 1p config are able of up to 100A but voltage can drop to 2.3V at this load. This gives you 230W peak per cell. With 8 A123 cells you will have around 2000W at your finger tip. Your limitation will be the Mamba max ESC which most likely is able of short peaks around 100-130A: up to 1400Watt (more then enough for a buggy).
Depending on the height of your body you might be able to fit 5s2p (humpback config 3+2 or 4+1) which would give you around 31000rpm under load.
kyosho501x
kyosho501x's Avatar
06.18.2008, 11:30 AM
well i got one mount off then my dremel died well off to the charger
