Shark413
Shark413's Avatar
06.19.2008, 02:12 PM
Hi, I had the same problem. I found these and they hold up well, they are extra heavy duty velcro straps. They come in several different lengths, but I normally cut them in half, use a soldering iron, and put a hole in the ends (the heat seals the edges of the hole and makes it stronger). I then clamp the ends down to my battery tray/box using large washers that have a rubber gasket (so they don't cut into the velcro). Or you can get one that is long enough to wrap completely around your battery. Just keep in mind that these straps are thicker than normal velcro.
http://www.mcmaster.com/
Part # 3955T72
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
VintageMA
VintageMA's Avatar
06.19.2008, 02:47 PM
I actually use the velcro straps for wrapping computer cables in data centers (free because I work in one ;) ), but I haven't had a single problem with them very strong. You can get them at any computer store.
“Everyone has a right to be stupid; some people just abuse the privilege.”
