Pdelcast
Pdelcast's Avatar
06.23.2008, 09:20 AM
Originally Posted by Django View Post
I'm searching the Castle Forums here looking for some guidelines for setting up my MMM in Castle Link. I'm coming up dry though. Maybe it's the words up searching for, particularly the "motor timing" setting on the "basic" tab.
As you probably already know, you get several choices.
Highest (20)
High (15)
Normal (10*)
Low (5)
Lowest (0) Best for Bashing it says.
Normal is what it auto detected for me and my setup. MMM 4s (two 2s in Series) a Tekno 1515 1Y. I thought there was 0 degrees of timing on these brushless motors. Or am I getting my terms confused here?
I'd really like some opinions on these issues.
I know what the search button is for, too.
Thanks
Try setting "timing" a little lower, and set "punch control" a little lower.
I agree with you on the connectors -- we ship those big 6.5mm connectors because that much current needs a big connector. Some of our 1515/1Y setups draw as much as 125A continuous at full speed.
You can also try gearing down, current draw is directly related to gear ratio -- so if you want tot try limiting current, the easiest way is by changing gear ratio.
Patrick del Castillo
President, Principle Engineer
