Mamba Max on 5s
droopy
Mamba Max on 5s - 06.24.2008, 01:02 AM
I have read on some posts were guys are running a MM on 5s of lipo what needs to be done to do this. If it cant be reliable I dont want it ill just wait for my MMM to get back from castle but I would like to do the mod so I could use it for a backup.
Man I hate dusting my RCs I would rather drive the dust off.
jnev
jnev's Avatar
06.24.2008, 01:24 AM
From what I hear, some MM ESC's work on 5s and some don't. The first things you will need to do to the MM ESC though is add an external BEC, a cap(s) and a fan will help very much as well.
I personally wouldn't risk it though, and just wait for your MMM...
azjc
06.24.2008, 03:08 AM
I havnt done it yet, but from what I have heard disable the LVC and the MM will arm, than you have 2 options either run with an external LVC or risk it...I have thought of doing this with my Rustler...I am still working on my FLM upgrades with the Rustler, and my BL Revo is still going strong so no rush
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.24.2008, 06:38 AM
Luck is what runs some MM's on 5S. ESC is rated for 3S. Will have to run a external BEC and probably 2 Fans
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
06.24.2008, 07:56 AM
dude. considering the cost and the short time beofre the MMM is available, dont risk it!
a few more weeks isnt going to hurt, having no esc and having both sitting in castles office would be much worse...
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
VintageMA
VintageMA's Avatar
06.24.2008, 08:57 AM
I have two MM's - one will run on 5S and the other will not (only up to 4S). The MM LVC will auto-detect up to 4S, for more than 4S you just have to set the LVC to a custom value (ie: 16 volts @ 3.2v/cell or 16.5 @ 3.3v/cell).
I have a Novak 25mm mounted on top of the heatsink (small screws will nicely just thread themselves into the heatsink) and I use the CCBEC. No cap mods in place. No problems with temps at all ever going above 120-130* even when pushing 1000-1200 watts through the ESC.
I say no harm in trying it - it'll either arm and work or it won't. Just take it easy for the first few runs pushing it a little more each time and keep an eye on temps.
“Everyone has a right to be stupid; some people just abuse the privilege.”
Sammus
Sammus's Avatar
06.24.2008, 09:30 AM
I read recently about someones frying on trying to arm it with 5s. I think it was DickyT
Yep found it
I plugged in my 5s pack, flipped the power switch on the MM and it smoked as soon as it armed. I didn't even get to pull the throttle.
brushlessboy16
brushlessboy16's Avatar
06.24.2008, 09:56 PM
My Mamba works fine on 5s, with a multipole motor at that.
speed demon
06.25.2008, 12:12 AM
I've been running mine on 6S without a problem. I'm using a cc bec, fan and mod one done.
I've also ran it on 5S but the custom LVC didn't work for me. Also it sometimes worked on 4S but sometimes it didn't. Just a heads up.
Sammus
Sammus's Avatar
06.25.2008, 12:24 AM
6s on a mamba max? Wow first I've heard of it! Does it arm when fully charged at 25.2V?
speed demon
06.25.2008, 12:29 AM
Yep no problems. I'm running a 1600 medusa in a rustler so I really don't think I'm pulling many amps. The run time is jusy sick with a 4000mah dymond bat. and the temps are way down.
droopy
06.25.2008, 12:34 AM
well its a mixed crowd to 5s or not to 5s. I think ill but another MM and give it a go and hey if it wont arm my bandit could use it.
jhautz
jhautz's Avatar
06.25.2008, 12:45 AM
They are hit or miss running 5s. Some do... some dont... I woulnt say that frying the minute you flip the switch isnt normal on 5s. I wouldnt let one incident sway your decision. ANd absolute worst case scenario it will cost $50 to get a new one from CC under the replacement plan. But odds are it will either work or just wont arm.
I have 2 old ass MMs that have been fed a steady diet of 5s since the first time I hooked them up. I never had a problem with either of them. I have another that won't arm at all on anything more than 4s. (that one went into the CRT.5 on 3s)
( funny thing though.... By the time you buy a MM a CC BEC and a fan it is almost the same cost a MMM if they were actually available.)
to make it...
or break it...
Silent...But Deadly
droopy
06.25.2008, 12:55 AM
Sorry but what is a mod one?
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.25.2008, 12:58 AM
I have 3 old MM that all work on 6S A123~5S lipo. Voltage cutoff disabled, UBEC and just added additional caps. I've also seen a new MM work on 5S, with just a fan and CC BEC.
Here's one that I just did, which I bought from a forum member here.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
