droopy
06.27.2008, 01:02 AM
here is my setup
MM esc
cc bec
14 cells ep 4200 or maxamps 4700's
Medusa 36-50-3300
18t pinion
roadboy chassis
proline bowties on max offset rims
shortened revo drive shafts
Dog bone center driveshafts
spektrum dx 3.0
Here is my temps on last run esc 97 deg, motor 94 deg , batts 109 deg
I just run the MM esc not there motor there motors just wont hold up in a heavy truck
I was thinking about useing the medusa 36-60-2000 in the esavy but after seeing how much power it has in my x1-crt it is to much motor for the savy drivetrain the 50mm long works great in there.
SATAYO
06.27.2008, 01:08 AM
Droopy,
Can you send me some pics of you shortened Revo shaft setup...?
I would great appreciate it...
-ST
--Team3Six--
droopy
06.30.2008, 12:49 AM
Originally Posted by SATAYO View Post
Droopy,
-ST
I dont realy recomend a revo shafty setup due to the fact that the revo shaft diameter you have to grind the ears that your shocks mount to so you have to relocate your mount points to the ouside of the arms, You also have to use your stock ends from the e-savy and put them on to the revo shafts there is some slop there so I made small plasic shimms the next problem is the pins on the revo shfts are longes so I found you have to cut them then hammer it a little to flair the ends to keep them in place.
I have not broken a revo shaft but the stub axels or the input side are prone to snapping.I have even switched to tmaxx stubs wich only reqire a bearing switch (2.5 model)
I recomend to completely switch to the 2.5 tmaxx or e-maxx shafts but you will still need to use your stock end that hooks to the diffs since tmaxx are 6mm and e-savy are 5mm.
