Duster_360
06.28.2008, 11:34 AM
Let us know when they have it released, thanks!
Duster_360
07.04.2008, 11:31 AM
Just a followup - really pleased the way I caa watch and store charge data on batts using this v1.5 firmware and EOSView with my 0610i - charged a 3S lipo last night and it was neat watching the cells come into balance on EOSView.
One thing I've noticed - the USB port I used to install the PRGUSB software for connecting with the charger will not work with CastleLink software. I was trying to set up a MM and 2 CC Becs from the same USB and was having trouble - CC was telling me it couldn't find a CastleLink device while connected to either MM esc or a CC Bec.
I tried a different set of USB ports (laptop has a set in back and a set on the side - both are USB 2.0 protocol) and CastleLink worked like a champ. If you make this upgrade, you may want to be aware of this. Seems like the PRGUSB adapter installed for the firmware upgrade "takes over" that USB port or alters it in some way.
Jeremy1976
07.04.2008, 04:42 PM
Anyone have a picture of the plugs/adapters all plugged into the charger? I am not sure if I got the right stuff. I got like 3 different things here.
tc3_racer_001
tc3_racer_001's Avatar
07.04.2008, 06:35 PM
when i got mine (the adaptor cost $1.95 and the cclink like thingy was 19.95) i havent got the charger yet though
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Duster_360
07.05.2008, 05:34 PM
These are the 3 pieces -
And here, they're connected to my 0606i -
tc3_racer_001
07.05.2008, 06:48 PM
whats the other servo wire for? a temp sensor? i havent rtecived my charger yet .... stupid bpp... o well, i got a 10% discount :)
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Duster_360
07.05.2008, 07:20 PM
Yeah, the other wire (red/white) next to it is the temp sensor. I have an Ice charger too and my experience with its temp sensor was disappointing - the temp it reads lags way behind the batt temp and makes it mostly a curiosity and I won't use it.
The Hyperion temp probe is much better, it has much better contact with the batt surface for starters and follows batt temp pretty good.
tc3_racer_001
07.19.2008, 07:53 PM
just letting people know 1.6 is out.
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Jeremy1976
07.20.2008, 01:03 PM
Where is "device manager" located on the computer? I have the firmware downloaded and then moved it to my desktop. Is moving it to the desktop considered unziping it? Thanks
Duster_360
07.20.2008, 01:48 PM
Click start, find 'my computer' in the list on the right. Highlight it, then right click it, then click properties in that list. A new dialog opens - in that click the hardware tab. You will find device manager listed first in that list.
No, moving it to the desktop is not unziping it. You need to run winzip (or something like it) to unzip the file. To check, highlight the file you moved and right click it. In the list that comes up click properties. At the top if it shows type of file as WinZip File, you will need to unzip it.
If you have Winzip installed, dbl click the file on your desktop - that will start the unzip process, tell it to extract file to your desktop.
Jeremy1976
07.20.2008, 09:23 PM
Got it updated and thank you for the help. What is the biggest change to this new update? Now that I did it once it will be a piece of cake in the future. Thanks again!
tc3_racer_001
07.20.2008, 09:48 PM
yep, the only issue i had was u had to turn the supply on really quickly or it froze.
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
