07.06.2008, 06:36 PM
It's the MM. (Mamba max) I've tried connecting to other usb ports. It doesn't help. Yes, i've been plugging into the side of the esc as well.
VintageMA
VintageMA's Avatar
07.06.2008, 06:51 PM
Are you running Vista or XP? If Vista, do you have .NET 1.1 installed?
Have you tried that USB cable with another MM? Also, if that's your only MM have you tried another USB cable?
I would recommend uninstalling any versions installed and delete any folders under C:\Program Files\Castle Creations. Reboot and try to reinstall 3.051 or higher.
“Everyone has a right to be stupid; some people just abuse the privilege.”
07.06.2008, 06:54 PM
Running XP.
