rootar
rootar's Avatar
07.08.2008, 07:17 AM
a feagio 9L works GREAT, all the power youd ever need in a slash, and doesnt even get hot to boot, i also get over 45mins of runtime on my 5000 3s, you have to becareful about it tho as mine blew one of the rear tires apart, not from hitting the body either just came on to the front straight gassed on it and BAM tires starts flopping all over.
rcsammy
buggy beater
rcsammy's Avatar
07.08.2008, 08:31 AM
sounds fun
forgot to say im looking for 40-50mph(nitro speeds) from it and would like to be able to gear it and run fine on grass(short), dirt and tarmac without overheating
  Send a message via MSN to rcsammy
rcsammy
buggy beater
rcsammy's Avatar
07.08.2008, 10:23 AM
also does anyone know where i can find the manual for a hyperion EOS0606i charger? just got one 2nd hand but its been sent with the wrong manual
skellyo
skellyo's Avatar
07.08.2008, 10:41 AM
Originally Posted by rcsammy View Post
sounds fun
If you haven't driven it yet, I suggest you do so before you decide you want that kind of speed out of it. While it would be fun to drive in a straight line at 40-50mph, it will not handle high speed gracefully as it has a high center of gravity and tends to traction roll quite easily. You may find yourself running after it quite often to put it back on its wheels at those speeds.
Superbasher
Superbasher's Avatar
07.08.2008, 12:17 PM
Well so does a Rustler so nothing new there
  Send a message via MSN to Superbasher
Maciolus
07.08.2008, 12:37 PM
Consider Medusa MR-036-050-3300V2-3F. It should be enough for 2WD.
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
07.09.2008, 02:44 PM
I had one in a pede on 3s. It's great!
rcsammy
buggy beater
rcsammy's Avatar
07.09.2008, 03:26 PM
does mike sell them anymore?
i can see a 9XL but not a 9L
any ideas on this?
Originally Posted by killjoyken View Post
Do you have a pic of how you fit the heatsink clamp? I tried to fit it but it looked like I'd have to carve out the back of the tranny. I just put an 8L/MM combo in my Slash, but haven't had a chance to run it yet.
i was thinking the same, looking at the pictures of it i think the fins only cover half of the motor can so it might be alright
rootar did you run the clamp on it in a slash/rustler/pede?
skellyo
skellyo's Avatar
07.08.2008, 03:15 PM
It's quite a bit worse than a Rustler in terms of CG and traction rolling. I've got both and my Slash is on it's lid far more often with my moderately powered BL setup.
Superbasher
07.08.2008, 03:29 PM
Fair enough, I just thought they were similair in terms of C of G.
rcsammy
buggy beater
rcsammy's Avatar
07.08.2008, 04:07 PM
iv run quite a few packs through it and yes it does roll alot easier than the rustler but you get used to the handling after a while and can easily drive it without rolling
i deffinatly want to get brushless
im still leaning towards the mamba 5700 at the moment though, mostly because its waterproof which means i can go to the track and it doesnt matter if theres puddles or its raining
edit: and thanks for the link to the manual :)
