ah-see
07.09.2008, 04:08 AM
Originally Posted by mtbnjim View Post
is it better to Parallel two 6s lipos or to Series two 3s Lipos...assuming you have equal Mah and weight- which is better for performance and/or life of battery over time?
Assuming the discharge rate on both setups are exactly the same, two 3s in series would be better because there are less cells which means less chance you get a dodgy cell, also less connections = less resistance and it would be harder to keep the 12 cells in balance as opposed to the 6 cells.
