Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
Red face 07.10.2008, 12:43 PM
Got another Velineon motor and another combo so the motors are both new, just one old ESC, checked both ESCs and they are the same version. Soldered an H connector out of Deans to connect 2 batteries and 2 ESCs.
Also put on RPM tru-track.
When I disconnected the motor wire on my old ESC the bullet pulled out of the case
tried soldering it back on. Got a short 10 min. run and things heated up a lot.
synced the motors and it ran much smoother and cooler for another 20 minutes. The run ended when I was cruising up a grass hill punched the throttle to 2/3 and it rotated backwards onto a driveway and skidded on the deans plugs and grinded the motor mount. The bullet came out again, don't know what to do.
ID:	4964   Click image for larger version
The timmy - Revo 3.3 MM 9XL 4s , Rustler MM 4600 3s
The ferty - Dual velineon Revo 3s, Rustler velineon 3s
