azjc
07.11.2008, 01:11 AM
both of your motors you have listed draw a lot of amps, if you have the cash buy a couple of new motors that have a higher wind, and also check the timing for the ESC if they are not at 0 this will cause heat...running the timing does speed up the motor a little but not worth the heat buildup IMO
also make sure you are using an external BEC with the onboard bec disabled
macr0w
macr0w's Avatar
07.11.2008, 01:19 AM
Yeah, I keep the timing down to 0 Lowest and the punch has been moved all around from disabled to 90%.
I used the CCBEC on the battery leads of the MM. Of course I pulled the red wire from the lead to the receiver.
After I went to a receiver pack I used it as a voltage regulator. But I took it off because it was glitching the esc.
