Ev1er
07.14.2008, 12:19 PM
Then I should get the 2000kv motor and 2 x 2s lipos ?
azjc
07.14.2008, 12:26 PM
that would be good and if you feel it is too slow you can gear up but that would put extra resistance against the motor and this can cause heat buildup and reduced run time, but with a decent motor like a Medusa it may not be an issue...there is a give and take with BL setups
