DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.16.2008, 10:22 PM
Well finally the rain went away and I managed to get down to my local track. Using the 13T pinion and changing from 3000 in front diff and changing 5000 in centre to 10 000 couldn't wait to see of the changes. At 10.32am I was going out of the pit lane and flying down the main straight. At 11.17am I was driving back into the pits as battery was starting to run slow. 45 MINUTES OF RUNTIME I never had to turn off the battery once, just kept going and going. Temps were Motor - 160F, ESC 111F & Battery 108F. I checked the voltage of the battery with the multimeter and it was 16.45V. I charged up this battery about 3 - 3 1/2 weeks ago. Back to work tomorrow, so not going to be able to use it for another 5 days.
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
07.17.2008, 02:58 AM
all i can say is wow. what capacity were u using? 5000 or 6000 im guessing, any more than that and it wouldnt fit!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
07.17.2008, 03:21 AM
TP 5S 5000 25C. I was probably flat out racing 60% of the time, 38% was doing sections over and over trying to get the right line and the other 2% was on my roof from landing wrong.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
mxracer
08.01.2008, 04:43 AM
i have no idea how the hell you get runtimes like that , this is my setup
neu 1512 2.d/f
hyper st pro truggy
52/12 gearing
mamba max , 15v cutoff voltage
5s flight power 4900mah
everything is pretty close to the same as yours , yet i get about 9-12 mins runtime
i have a jammin cr pro buggy , i will try replacate your setup as close as possible , but i very very much doubt i will gain another 30 mins of runtime
HOW DO U DO IT ??
losi 8ight-t 1515 tekno 1Y/MM 4s/5S flightpower
losi 8ight-t 1515 tekno 1y/MM 4s/5S flight power
RIP 4x MMM . MM still lives on !
ffactory666
08.01.2008, 05:15 AM
neu 1512 2.d/f
hyper st pro truggy
52/12 gearing
HOW DO U DO IT ??
You should be getting minimum 20 mins with the battery you are using.
Somehthing isn't right.
What temps are you getting ?
Your driveline might be binding some were causing drag and robbing you of run time .
Check your diffs , cvd's Centre front and rear ( especially the pins ) and bearings
