cemetery gates
07.19.2008, 09:35 PM
Just pop into the local "AutoZone" and ask them to put it on the tester(its free). They will put you in the right direction quick and you will be on your way. It sounds as if you have a bad battery since your system is putting out the voltage. Get the car running and disconnect the battery. If the car dies, then you have a bad alternator. If the car keeps running, then your battery is bad. Good luck with that.
I'll have to bring it there at 8am tomorrow because it closes in like 25min and by the time I get there it'll be closed. Huh...
