i also read somewhere the spektrum dont work to well with cc, been using a spekie for long time with no probs. check all your connections mate, could be a loose one. what motor are you using with the MM to cause cogging? maybe unscrew the board from the plastic base & check the borad throughly to make sure nothing's been damaged...
