JThiessen
JThiessen's Avatar
07.21.2008, 04:01 PM
There should also be a percent capacity level that you can set - not sure if it goes down to 50% though.
RUSTY XL-5
RUSTY XL-5's Avatar
07.21.2008, 04:45 PM
thanks everybody!
Another question, I just tried to balance my lipo but the charger says "balance voltage too high" It wont let me charge the batt at all. I've tried looking in my manual, but it is terrible. What do I do to get the balance voltage low enough? Do I just run the bat until its low?
Sorry for all the questions, but I new to lipo.
I will spank a nitro any day...guaranteed. :)
Duster_360
07.21.2008, 06:02 PM
This is what TCS - 'Terminal Capacity Selection' is for, top page 3, then more detail explanation after network charging on p5. Runs from 0 to 100% for lipo, other batts may have higher range.
Basically after batt is set up if you want it to stop at 50%, enter 50% in TCS, charger stops at 50% capacity based on the setup you input. Want 80%, enter 80% in TCS. Couldn't be easier - name could be better though, its not real obvious what TCS is for.
