View Poll Results: Which motor (read post first plz)
Neu 1515 2.5d f 1650kv 11 33.33%
Neu 1512 3d s 1700kv 22 66.67%
Multiple Choice Poll. Voters: 33. You may not vote on this poll
rootar
rootar's Avatar
07.22.2008, 09:11 PM
well what diameter are the finned nue motors? i think the smooths are 39mm arent they and the finneds are 42mm. i know i could easily fit a 12 tooth or less with the XL and mikes heatsink and prolly the smooth can but i dunno about the finned, mike only has a 1512 2000kv finned neu while impackt has the 1512 1700 kv smooth can.
will the smooth can be good enough and where can i find a heatsink for it?
jhautz
jhautz's Avatar
07.22.2008, 09:57 PM
you dont really need the fins with a Neu. I run the smooth 1512/3D with no heatsink or anything and I get temps around 160 or so after a 20 minute main. The neus run cool enough. The fined probably do run cooler, but how much...
to make it...
or break it...
Silent...But Deadly
bdebde
That's All Folks!
bdebde's Avatar
07.23.2008, 12:43 AM
Finned can is 44mm. If 12t is smallest pinion that will fit with an XL (36mm), then a 15t would be the smallest you could go with a smooth Neu (39mm). And 20t with the finned (44mm).
.... The fined probably do run cooler, but how much...
About 20 F according to Steve Neu.
