Sammus
Sammus's Avatar
07.24.2008, 10:23 PM
I was just thinking. The mamba max says you can run 12 cell NiXx. I've had my nickel batteries at 1.5V off the charge before, 12*1.5V = 18V.
A123 is 3.6V at full charge, 5*3.6V = 18V.
So technically, it should work right? It must be within the design spec of the MM, even using the built in BEC...
entjoles
07.24.2008, 10:34 PM
i cant think of why it wouldnt work for you, on mine (older one) i have to drop the voltage a little when the 5s lipo comes off charger (21v) to about 20.3-20.5 and then its all systems goooooooooooooooo
