07.27.2008, 12:37 PM
Yep, it has m4 thread holes, and they are 30mm apart. A std 540 mount is m3 holes, and 25mm apart.
J3110
07.27.2008, 01:05 PM
Which would be hurdle number three unless I decide to mount it in the E-Revo...I guess they'll mount up using some combination of standard mounting holes in it's motor plate.
If that ends up not being the case, I can always modify the E-Maxx motor plate although I'd rather not.
This motor was originally going in the E-Revo anyways.
Really, it'll just need to last until I get my castle combo, but we all know there's no telling how long that'll be and weather or not it'll work right the first time.
Also, if the 7xl or MM in my E-Maxx goes out, I'll have a spare motor and ESC.
If everything keeps working like it should, the T-Maxx will be getting converted to brushless...finally...
07.27.2008, 01:14 PM
The front endbell screws on. I took one of mine off and drilled/tapped the std 25mm motor pattern on it. Not very difficult, you just need an 1/8 drill bit and a m3 tap. Put the holes 12.5mm from the center of the shaft, or 9.5mm from the side of the shaft.
The kb 45 motors are great. I have 4 of them and they make plenty of power and run cool too.
J3110
07.27.2008, 01:20 PM
Or I could: just get the right screws. ;)
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
07.27.2008, 01:33 PM
Could you not just put the motor in a vice (light pressure, with rubber or rag around it to protect it), hook up the ESC and battery and have it spin the shaft slowly (1/4 throttle or so) and use a file to grind it down a bit until you can get a 5mm pinion on easily? That would be how I would do it, except I don't have any 5mm pinions.
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
lutach
lutach's Avatar
07.27.2008, 01:49 PM
I'm not 100% sure, but I think 32 pitch is something like 0.8. Here are a few part numbers from https://sdp-si.com/eStore/:
32 Pitch:
S10A6Z-032H024 (24T, Hardened Alloy Steel, 0.25 face width). The bore D. is 0.2498 and some places show it as exactly 6mm, but others have it a tad bit larger (6.3). If it is larger, see if you can find some sort of brass tube that has walls that are 0.04 (roughly 1mm) thick.
0.8 Module:
A 1Y 2MY08020 (20T, 416 Stainless Steel, 6mm face width, no set screw)
A 1C 2MY08020 (20T, Carbon Steel, 6mm face width, no set screw)
A 1Y 2MY08024 (24T, 416 Stainless Steel, 6mm face width, no set screw)
A 1C 2MY08024 (24T, Carbon Steel, 6mm face width, no set screw)
A 1Y 2MY08025 (25T, 416 Stainless Steel, 6mm face width, no set screw)
A 1C 2MY08025 (25T, Carbon Steel, 6mm face width, no set screw)
Find a machine shop and have them put hole(s) for the set screws on the hub.
J3110
07.27.2008, 04:16 PM
Brijar!!!
That is a fantastic idea. I hadn't even considered using the motor as a lathe, itself.
I'd need some kind of measuring device or method that would ensure a true lathe, though. I guess trying to fit the pinion every so often might work...just work my way in toward the motor.
If anything, I expect to need a larger pinion. Depending on what my choices are, I am hoping I won't have to modify or fabricate anything...not that I am opposed, but wouldn't it be nice?
07.27.2008, 02:09 PM
Originally Posted by J3110 View Post
Now that is cool, I had no idea that traxxas would do that. I may have to pick up an ervo mount plate and that motor mount. Kb45 motors are great, and cheap too. A maxx or revo will never put much of a load on one. I run an 8l in a ofna gtp 1/8 onraod car, and it does not even get warm, even geared for 50mph...
