lutach
lutach's Avatar
08.01.2008, 11:17 AM
Maybe... I'll try to find somebody here who have a standard FM radio and try it.
If all goes fine with FM radio, i'll run with that and keep my Futaba 2.4 for my baja.
This is the e-mail the sent from MGM to the fellow RCer:
"some of 2,4 GHz RC equipments use "HRS" modulation. Older controllers donīt know this modulation, checking signal from receiver, and no working.
-Please, try again programming min., max. and neutral throttle position. When controller will donīt work aftter this, necessary is send your ESC to upgarde SW to us. Newest ESC working with these RC equipments without problem."
Keep trying to get the new firmware loaded to your ESC. The issue might have been fixed.
david lamontagn
08.01.2008, 11:40 AM
I've send my controller to MGM last winter for the SW upgrade. Now i've try to run it in HRS mode and in normal PP mode, and nothing to do.
I don't know why i've the succesfull message when i download the 3.23 SW and as soon as i return on the controler framework to read data, it's always the older 3.21 version is shown
Desmo
08.01.2008, 12:26 PM
search the forums here others had problems updating the firmware
david lamontagn
08.01.2008, 01:37 PM
Yes, i've read all other post about that, and not able to have a clear and precise answer
So i'll make my own test
Quattro 83
08.01.2008, 01:40 PM
Hope you manage to upgrade your software, sure your MGM will work fine when you do!
I've read loads of negative posts regarding MGM's which really put me off buying one, but I recently took the plunge, and bought a new 16018. It's honestly one of the best controllers I've ever used.
I have 2 MM's, had a Quark Monster, and an MMM which is being repaired, and the MGM has (in my opinion) been the best. It runs really cool, (I bought the model with fans attached) is easy to program via the pc, and has an incedibly smooth start up with Neu motors, right up there with a Quark. Yes the MMM, has more features, and an unbeatable price, but new MGM's with the latest software are great controllers!
david lamontagn
08.01.2008, 02:02 PM
I know, appart the brake issus, i realy like this controller. But i don't understand why i'am not able to download the 3.23 software.
Which version did you have?? 3.21, 3.22 or 3.23?
Quattro 83
08.01.2008, 02:36 PM
I have the latest 3.23 software, and apart from having to set the throttle end points on my DX3.0 to 125% it's been very, very easy to set up.
If I get some time at the weekend I'll try and read up on upgrading software, as you know the instructions aren't exactly the easiest to follow, lol!
I'm sure with the amount of knowledgeable people on this forum someone will be able to point you in the right direction, hang in there!!
