rootar
rootar's Avatar
08.05.2008, 11:26 PM
Yes i run mine on 5s, i bought this one from artur and he had already used it on 5s, if yours has the mod1 try disabling the cutoff at first then if it does arm and work you can try a 16.5v cutoff (anylower and the mm recognizes it as a multiple of 3-3.2v and wont arm) also i couldnt get my controller to arm with the 16.5v cutoff with any other software than 1.16 the newest didnt work.
as artur told me trying to use the cutoff is on your own, i found a way for mine to work, no way of knowing if theyll all act the same as mine........
