Byte
08.07.2008, 03:58 AM
Originally Posted by spaz163 View Post
Well it depends where you measure to. I just went and measured mine and I came up with 165mm (6.5") if you measure from the end of the pack to in between the balance and charge plugs. But if I measure from the end of the pack to the end of the shrink wrap around the charge plug leads I get 177mm (7").
So if you were using a low tray so that the balance and charge leads could just hang over the end of the tray, I would say 165mm and then use a velcro strap down the length of the pack in between the 2 plugs.
I have not been able to run this pack yet because of a faulty charger I recieved so I cannot give you any performance data on it yet. Oh and I have the 4s 4800 Zippy-R.
So, you measured till the blue stripe, right? That was 165mm? But can you say me the length of the pack from the end to that black cell? ( Look picture )
Ty in advance!
