rootar
rootar's Avatar
08.08.2008, 12:28 PM
Originally Posted by bustitup View Post
sir you are correct..these motors are sold on a Neu site and all the motors sell for about the same price weather they are 1515 or 1512......they are motors that have been used for testing or returned for some reason.......nobody got screwed...they also come with full factory warrantee also
btw what are using the motor in rootar?
i knew exactly what had happened, i had called about 3 weeks ago asking if they had any testers or rebuilt ones forsale, but they didnt have any at the time so i shelled out and bought mine from mike, but mine is the new updated version, with bigger bearings, flatspot on shaft, and thicker screwed on endbell, (basically a teckno version but black with holes in the ends.)
im using mine in an Xray 8xb on a 5s 5000 flightpower pack
if i was you id keep it these are awesome 5s and 6s motor from what i understand, but on 4s they arent quite as "explosive"
bustitup
08.08.2008, 12:43 PM
Thanks for the confidence Rootar......I also knew I was ok but do feel better since i called
anyway the 1515/2.5 has a 80 amp rating ....you guys think these batts would suffice?
NEW TrueRC 5000mAh 11.1V 3S1P 15C Pack
HIGH PERFORMANCE PACK FOR AIRPLANE OR CAR
Balance plug, works with all of our balancers. Can be modified for AF Blinky for use without adapter.
Size
28mm x 45mm x 160mm
Weight
395g / 13.9oz 12AWG WIRES
Discharge
Up to 75A Continuous
100A Max burst
Price
$89
Fits PERFECT into Traxxas E-REVO
with the L shaped bracket removed.
L shaped bracket is for holding down shorter packs and can be easily removed since this battery fully utilizes the battery bay. For best fit, install the battery into the bay with the wires first.
PERFECT FOR MMM or NEU motor setup and any other 6S capable ESC and Motor
Byte
08.08.2008, 01:44 PM
What do you mean with this? Do they sell motors that were not 100% perfect? And you can get them cheaper than normally?
Sorry my Englisch sucks like hell
ah-see
08.08.2008, 02:00 PM
Here take a look at this page:
http://www.neumotors.com/20061222/Special_Deals%21.html
Byte
08.08.2008, 02:04 PM
Originally Posted by ah-see View Post
Whoot! Thats awesome! Ty!
Just 1 question, they don't update that page often, right? Or why do you guys call them?
