08.10.2008, 10:58 PM
Trying to find a higher mah pack that is not longer is difficult. You can go up to 6000mah with fp lipos, but you will need a bigger battery tray. Mike sells a tray that will fit...
Look around, you may find a better price than tower hobbies has. You can go with any of the other brands I listed, they all use the same cells...
roweder
I got my MMM Combo!
roweder's Avatar
08.10.2008, 11:06 PM
the only one that i found that was better was a flight power 6s pack, but i don't have a 6s charger, I just ordered the battery tray from rc-monster like 30 minutes ago, but I'm not going to cancel it unless I find one with higher mah and 5 cells that's too big for the one I ordered.
  Send a message via AIM to roweder
roweder
I got my MMM Combo!
roweder's Avatar
08.10.2008, 11:13 PM
Now I see: http://www3.towerhobbies.com/cgi-bin...LiPo&search=Go
The one you chose is definitely the best, thanks so much
roweder
I got my MMM Combo!
roweder's Avatar
08.10.2008, 11:20 PM
wait, i found one on a-main from thunder power, a little less at $264 and it's 160mm, 25C rated and 5000mah, I'm thinking that I'm gonna cancel that tray.
roweder
I got my MMM Combo!
roweder's Avatar
08.10.2008, 11:35 PM
nah, I don't think I'll cancel it, thunder power is the only one that doesn't fit, Neu Energy has a 5000mah 25c/50c 5S pack that fits and it's only $250 plus it comes with a deans connector, but it also comes with a astro blinky balance connector and I need either thunder power or align compatible, maybe I'll be able to find a astro blinky female attached to a align male balance connector. I have the Losi charger, and it's max charge rate is the same as the battery which I am happy about, now i just need a li-po sack
