GriffinRU
08.11.2008, 09:05 PM
Originally Posted by mohanjude View Post
Can anyone guide me on the sttings that I need on the Dip switches on the controller for it work well with a Mutipole motor such as the Plettenberg Bigmaxximum or even a Tekno Neu motor. There are 2 dip switches on timing / frequency. Do they make a big difference?
Timing and frequency should be set to high if you plan to spin motor above 25000RPM.
Once you make some test runs you can lower your temperature by tunning frequency, timing is important if you have pretty light load.
mohanjude
Need for speed
mohanjude's Avatar
08.12.2008, 01:32 AM
Thanks
