Sammus
Sammus's Avatar
08.11.2008, 11:51 PM
Originally Posted by coolrunnings View Post
External bec's are known to fail as well I had a coolflight ultimate bec go on me and I've also read here on this forum that the castle bec fails and takes the servo with it because they send full battery voltage to the servo, a high quality unit like a hercules or a dimension bec is the only way to go.
Ahh dissing castle again . Upon failure they not only (potentially, depending how it fails) send full voltage to the servo, but to the receiver as well, which will usually kill it.
Yet another reason to stick to the internal BEC. :)
The castle esc is also apparently a little more noisy than the other brands mentioned (koolflight, herc, dimension) and can cause glitching if you have it near enough your antenna or rx.
