The EOS0610 has a setting where you can set your power supplies maximum output current potential. If this setting was to low it could cause your charger to limit your charge current.
Check out the manual HERE.
Yes I have set it according to the PS I´ve been using and have changed it each time I used the 1:1 battery...
Guys, he was using the 1:1 batt as the DC source - he wasn't charging it.
Something is set up wrong in your charger, or there is something wrong with your charger. You are using the supplied charging leads that came with the charger correct?
The charger is sensitive to the resistance of the power leads. I was trying one the other night and I could charge at all - it was for a tx batt with a male servo connection. This is a prebuilt adapter I bought for my Ice charger to charge rx batts and its 24" long and servo wire gauge. I tried to connect to my tx batt to charge it from my 0610i and it kept giveing me an error. I tried a diff charge lead made it 14ga wire and only 2" of teh servo wire - that worked.
If your leads have some resistance, the charger my be reducing the amps?? The charger does this for safety reasons and I'm not sure what else it does for safety. As long as the leads you're using are 14ga or better that should be ok. Have you dnloaded the manual (4 page) and checked the setup? If you've done all that, time to see about service, something's not right. Mine hasn't done anything like that - I've charged a123s as high as 8amps with no prob.
i charged 4s a123 @ 10A without probs, id suggest updating the firmware and seeing what else may be wrong... it may just be an error - unless you cant charge anything else liek that at all..
stupid question, but does the charger have a built in psu, if it does, this is your issue... 50W max... worth an ask!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
