glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.15.2008, 01:26 AM
As for the 35c rating.. I don't like it, unless it's head and shoulders better than everything else. Even if it can be rated in some opinions as a 35c cell, I personally would under-rate it if I were maxamps. For example, call it a 25c or maybe 30c pack... have it exceed the rating... and avoid all the critics nit picking.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
jayjay283
jayjay283's Avatar
08.15.2008, 01:42 AM
LOL good point with all their over rating that would be a start in the right direction
tc3_racer_001
tc3_racer_001's Avatar
08.15.2008, 03:29 AM
its very interesting that the cell only provides 3500mah of capacity at around 28C, is that normal on an enderland cell when its pushed to its limit? thanks. just seems crazy to rate the pack at 35c when it cant even dump 4000mah at less than 30C
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Semi Pro
Semi Pro's Avatar
08.15.2008, 08:46 AM
does anyone have graphs for other companys, maybe we could do an overlay, im not convinced that the maxamps pack i bought is going to be amazeing, the main reason i was buying from them was for the warranty after i had $600 in apogee packs die.
the other reason was, the 5 cell pack is under 550 grams, and it was only $220 and they were more than happy to build my pack 10 gauge with no extra charge
