bustitup
08.21.2008, 11:02 AM
This is a centre diff - i.e. on Brians script direct drive 1:1.
The ESC should mount up directly on the top plate - That is what the tail is for.
Just count the spur....
It does need some cleaning up - the rx/sevro plate is a bit messed up - you don't need the CF and mikes support.
So I can remove that CF plate out from underneath the aluminum one correct?
Also seems to be a random nitro motor mount left in place.
the plastic peice that sits in front of the battery tray (left front) this can be removed?
Worth getting the side pods
are you refering to the mud guards that came with it?
