Sammus
Sammus's Avatar
08.22.2008, 12:47 AM
Originally Posted by skellyo View Post
You must have something way wrong on your setup if your Revo crawls better.
Do you have drag brake set up on your Mamba? Why are you running such a cheap Lipo?
no drag brake, with that 55t brushed I don't need any, it will hold itself on any angle with drag brake set to zero - either that or slide down.
The lipos I just happen to have about a million of kicking around, theyre not the problem, its never lacked power and nothing gets warm. I run the battery on the links behind the steering servo, and the the electronics upside down under the battery plate. And yet the truck just tips so easily. I think the fact that it comes with the super firm springs out of the box doesn't help, it's so light the suspension never compresses, it's like it doesnt have any shocks at all lol. I've just received some alu shock bodies and the super soft (red) springs from amain. I won't be at home with my babies (read: cars :P) till sunday though, so I'll have to wait to give em a crack then.
skellyo
skellyo's Avatar
08.22.2008, 12:50 AM
The lipos I've got about a million of kicking around, theyre not the problem, its never lacked power and nothing gets warm. I run the battery on the links behind the steering servo, and the the electronics upside down under the battery plate. And yet the truck just tips so easily. I think the fact that it comes with the super firm springs out of the box doesn't help, it's so light the suspension never compresses, it's like it doesnt have any shocks at all lol. I've just received some alu shock bodies and the super soft (red) springs from amain. I won't be at home with my babies (read: cars :P) till sunday though, so I'll have to wait to give em a crack then.
Do you have any weight in your wheels yet? If not, definitely add some lead in each front wheel. A few ounces per front wheel will make a huge difference.
Sammus
Sammus's Avatar
08.22.2008, 12:53 AM
That was going to be my next step :P
I'm sure it'll come good, it's just not perfect out of the box. Then again, what is?
skellyo
skellyo's Avatar
08.22.2008, 01:00 AM
I keep forgetting that I have heavier wheels than stock on my kit version. I'm running Mayhem beadlocks that are 10.6oz each with a Losi Rock Claw tire and memory foam. The stock ARTR tire/wheel is only 6.1oz. Even at the weight my wheels/tires are now, they could use some extra weight.
