GO-RIDE.com
08.25.2008, 07:02 PM
Originally Posted by VintageMA View Post
The one problem I have with the CRT.5 more so than any other car I've had is that on any sort of grass surface it is extremely prone to flipping when you turn - even at very slow speeds.
What setup are you running on the .5? Mine does great on just about everything. My 10th truck is a bit more stable overall due to both greater width and length, but 4wd .5 is more fun to drive. With truck tires I run the rear bones a bit below level and set the front ride height for chassis level. With buggy tires I run rear bones level and front again set up to level the chassis with the rear. I had some tip over problems in the past, but it was because I was running too stiff of springs.
E-8ight - Tekin RX8 2000kv/4S
VintageMA
VintageMA's Avatar
08.25.2008, 10:36 PM
Running the medium blue in back and white hard in front with stock oil weight. With the Anacondas on ashpalt it is rock solid and hard to flip. With bow ties, dirt hawgs etc on grass it flip pretty easy and is a little bouncy on the rough stuff. I tend to run a little bit of pre-load with the rears just a touch higher than level and the fronts a bit more as the front tends to bottom out when braking. If you want I can check on the mounting holes used for the front and rear.
“Everyone has a right to be stupid; some people just abuse the privilege.”
GO-RIDE.com
08.26.2008, 12:51 PM
I ran the same setup for a while and had similar problems on our local clay track. With the white F & blue R spring setup the car would clip something on the inside of a turn and the car would flip. A good test is to place the car on a flat surface and lift one front wheel. With the white springs you will notice that the shock on the wheel you lift will not compress. This is why the car flips. I found with stock shocks I could only run the Blue F & Grey R spring combo. I would the play with higher damping pistons to keep the car from bottoming too much.
In the end I did the Traxxas Revo shocks on the front and Ofna LX 1 front shocks on the rear. Now I can run soft springs for stable handling and use the larger damper to control big hits. I have a post about these mods: http://www.rc-monster.com/forum/showthread.php?t=11153
