08.27.2008, 07:26 PM
Generally yes. Also they usually are a bit larger, have a wider stance, larger tires, more ground clearance, F/R diffs have a higher gear ratio, and the CD usually has a larger spur. The gearing changes are there mainly to compensate for the greater weight and larger tires.
