08.28.2008, 10:42 PM
Consolidated Listing - Thank you all
- 9xl with broken rotor
- 2.2 wheels for a CRT.5 - The ones that don't use hex's...
- 3.5/4mm bullets
- GTP pipe
TakeDown
- A never used 27mhz 2ch radio "Futaba" with receiver.
- Two packages of reusable large zipties.
- A 75mm comp fan
- Some micro-t spares.
- Spare 30cc pipe "bought a better tuned one and its on its way".
- Micro-t stock charger. "needs plug".
Brushlessboy16
- 40 330uf 25v caps
- 75mhz 3ch rx
Rusty XL5
- HPI Nitro rush driveshafts (dog bones)
Trev3813
- hot bodies HR-3 AM 27 Mhz 2 CH Receiver, works great, compact,
- Airtronics 92721 27 2 CH AM Receiver, works good, compact
- Duratrax RX-100 AM 2 CH Receiver, out of a vendetta works good
BenSF
- CRT.5 Nitro parts
- 3 female 6mm connectors
- traxxas 3ch radios and receivers(in varying condition. TXs are okay receivers need new antenna.)
SuicideNeil
- CRT.5 Nitro parts
Rootor
- micro-t stock tires on yellow wheels
- few different reciver boxes off nitros
-9v 200ma charger/power supply
-stock mlst2 aluminum shocks
-couple sets of losi springs, i know there are 2.6, 2.9, and another rate i idunno
Cheesecake
- airtronics 94737 servo wires were repaired but it works
- ofna am radio with reciever and crystals
TexasSP
- New-1 Pair Proline Velocity 6 40 Series Wheels
- New-2 Johnson 550 Sized Electric Motors (basically equal to the traxxas titans for e-maxx)
- Used-Posi-trac differential for e-maxx shimmed and greased (older 3906 diff ring gear and case)
- New-Stock E-maxx tires from 3906 maxx
- 1 Damaged Novak HV Brushed Controller 16.8 volt capable
Kona
-Tamiya tl-01 roller w/ tires and steering servo. Just need body, esc, motor and radio. 2 other parts cars go with it (could probably be combined to make another roller).
-crt .5 yellow dish wheels with losi bk bar tires. Tires are worn.
-Nitro parts. Fuel tanks for Muggy, Duratrax raze, and Cen Matrix. Pipe for Cen matrix.
