What pinion would you recommend? I have 20T and 24T mod 1 pinions, I was going to try the 20T on the 1515 and see if I need to gear down from there but with the torque of a 1521 I am expecting to be using a large pinion. I will most likely be running Big Joes offroad pretty hard so I'll gear a little short of normal.
if you want to go with a 1521 I would go with the 1.5d instead of the 1d...kv of the 1.5d is around 2000 and that would be plenty on 4s especially with the increased torque over the 1515 can
I agree 100%. The lower KV will help with the amp draw, thus saving some of your runtime (but you probably already know that).
