trev3813
Dsm needed
trev3813's Avatar
09.07.2008, 10:03 AM
Relax guys. Neu will be more then happy to repair your motor. Do a complete check up on your vehicle to see if anything is binding. Check your connectors. Check to see if the bearing on the motor is ok as well. Check to see if nothing is binding the transmission. I had an issue like that and found out it was my diffs that were binding causing my Neu 1521/1Y to go up to 145F (Which is not bad, but it was never getting over 120F). I opened my diff case and found the problem. I had forgotten to add shims and that caused just enough binding to give the extra heat.
I agree with him ^^ Hes smart
