TruckBasher
TruckBasher's Avatar
09.08.2008, 08:47 PM
Originally Posted by JaySki View Post
I am running a brand new NEU1515 1.5D, Stock Servos. My last MMM ran FLAWLESSLY with a UBEC, until I changed setting in Castle Link. Up until now, I left it all at defualts.. even the LVC.
Yesterday, I changed the LVC to 12.8, Punch Control to 70% and modified the throttle curve a bit. 10 minutes later it jerked a bit at slower speeds and died. Motor never hit 100 and the MMM was still relatively cool. Didn't even smell like anything burnt. No lights nothing. Disconnected batts and threw them on the charger, tried another set of Batts and still nothing. Only running 4S.
Prior to the changes in Castle link.. I ran the snot out of it the weekend prior. Had a few runs that hit 55MPH with no real heat issues and no problems.
Now that you mentioned it the first few packs on my modded V2 run fine until I change the LVC to a custom 1 and change the brake amount...after that I was able to run it for 15-20mins then it just stop working after serious cogging in forward and reverse....
Not sure if it make sense...not sure how the software affected the HW ...
E-Slayer direct drive to diff
