MetalMan
MetalMan's Avatar
09.10.2008, 03:35 PM
Looks like it would make an awesome project. Here are my thoughts:
-BL motor where stock engine goes (no-brainer)
-Lipo pack(s) using ~2100mah cells in fuel tank/brake servo location, perpendicular to the chassis
-if you want to keep the mechanical brakes, you could throw a mini servo (like Hitec 5245MG) at the rear of the BL motor
-ESC mounted above BL motor? (where the nitro engine's cooling head goes) or maybe the ESC could be mounted to a plate above the driveshaft
