alangsam
09.10.2008, 08:46 PM
i think the failure rates are much higher as i got one of the first MMM from tower and that was only a few weeks ago. takes people time to prepare and get them installed and the truck tuned up and ready to race. we are seeing the people that get these and then get them turned around very fast like me and others on this forum. i think you will see a lot more returns and posts once more people get them in the vehicles.
RBMike
RBMike's Avatar
09.10.2008, 09:46 PM
Bernie, JHautz linked post about the fan connector is right on the money as one of this products issues (there may be more issues, maybe not). I also have worked in integrated electronics manufacturing (23 years in silicon valley). This mechanical design for the fan, fan wire routing & the plug are all a big NO NO on a unit that will see lots of vibration & mechanical shock.
#1) The clearance between the fan & the fan cover is too small.
#2) The fan wires will ALWAYS get the insulation rubbed off by the edge of the board the way you have them now.
#3) The SMT fan connector connection to the board is nowhere near strong enough to take the beating it gets on the bottom of that board.
I have had that plug break off of 2 MMM's in 2 different vehicles (1 V1 MMM & 1 V2 MMM)
I love the smoothness of this controller but I'm on #4 & the fan, the fan wires or the fan connector has failed on 3 before the BEC later failed & now #4 has a broken fan & connector has fallen off the board. I understand that the trends seen on these forums are not an accurate reflection of the real failure rate & have argued that point on this very forum but I no longer believe the failure rates provided by CC. I've sent my concerns about the mechanical issues with the fan & connector to Patrick (on Version #1) & again to Thomas recently & now you. Hope someone is listening, sure would hate to ask for a refund & go buy from Losi.
