brushlessboy16
brushlessboy16's Avatar
09.28.2008, 10:19 PM
whew, rough night but im back.
I think im going to have a shot at fabricating my own components.
motor mount will be out of 2x2x 1/8th aluminum angle, and battery tray will be from 1/8th kydex plastic, going to try to make a die out of wood to use as a form.
and use another peice of wood as the die to form it.
is aluminum sturdy enough to tap into, or should i use a nut and bolt
09.28.2008, 11:27 PM
1/8 al is a bit thin. Go up to 1/4 or 5-6mm. Then you can drill and tap the edges. Kydex makes great trays. I like to use the velcro strap and cut slots in the sides to thread it thru.
brushlessboy16
09.28.2008, 11:49 PM
The only reason i said 1/8 is because i have it right here, ill try and get thicker stuff.. if no will just drilling through and using a nut work?
how would i bond the corners of te kydex?
trev3813
Dsm needed
trev3813's Avatar
09.28.2008, 11:54 PM
Jb Weld?
09.29.2008, 12:13 AM
I usually heat it and bend it, then just let it go. It is stiff enough not to need the corners or edges to be attached. I do use the velcro strap to hold the battery to the tray well, basically wrapped all the way arounf the tray and the pack. Never lost a pack, and I bash hard.
Not knowing your design, I cannot really comment on material thickness. Sketch it out and I will take a look. You cannot drill/tap the edge of 1/8 al easily and it will not be that strong.
Tags
cen matrix
