10.10.2008, 04:31 PM
LSP is easy(ish) use the RCM mount and rotate the diff and mount such that the motor is opposite the servo.
You then have bags of room in the rear for saddle packs...
If you search you should find my old setup - I mounted a plate between front brace and centre brace for elecs
NickRummy
NickRummy's Avatar
10.10.2008, 04:36 PM
Ahhh that does make sense. I played with putting the motor on the opposite side but never thought about flipping it up towards the front. I'll have to give that a try.
