jnev
jnev's Avatar
10.10.2008, 07:33 PM
Your buggy is looking great! Thats good to hear that the Kyosho motor mount fits well. The D8 shouldn't be too hard to convert after all. You took a picture from the side of the receiver box and motor mount, but its a little hard to tell if the pinion will fit. Is there enough room for it or is it a little too close for comfort?
ffactory666
10.10.2008, 10:19 PM
Looking great dude didn't even notice that you started your build until i posted my start today.
Looks like we did similar things to the receiver box .
Jnev the box has to be cut to allow for the pinion and adjustment for the gear mesh , you can see pics of this in my D8 Corr truck thread .
FG101C what pinion are you going to run with that set up , i'm going with a 17t with my 5s 1600kv motor set up .
FG101C
10.11.2008, 02:16 AM
I plan on running a 13 tooth pinion on 4s 6000mah, 2200kv. Trying to make 20 minute mains. With my 8-T I get exactly 20 mins with a 10 tooth 4s 2200kv. That is until my driving gets smoother and maybe I can squeeze out a little more.
The fit between the pinion and box is tight, I will figure all the little details out once I have everything.
