10.14.2008, 12:26 AM
Oooh, 3100kv! Perfect for me.
IMO, the 2300kv 70mm would be perfect. Otherwise, the 2200kv 60mm would be my next choice. Actually, you might think this is crazy, but the 3100 60mm on 4s geared down would probably work quite well too. Yeah, it would be spinning close to 46k rpm, but that should be just fine. Would be taking a page out of Novaks book (use a smaller motor that revs high instead of a larger lower-revving motor). Might want to check Griffins motor calc to see where the efficiency starts falling.
10.14.2008, 10:00 AM
Dang, the 70mm motors sell for under $125... You can't go wrong there.
I would like the 1200kv model to run 10s on, maybe with a pair of 5s rhino lipos... That would be a cheap setup, and pair it with lutach's 10s esc... Under $500 bucks for a hv car system!!!
rchippie
rchippie's Avatar
10.14.2008, 11:09 AM
I just had my friend dave order me a OFNA ultra GTP . I will be using the medusa 70mm 2300 kv motor on 4s. What size pinion would be good. Im came up with this using a 13t pinion .
Differential Ratio: 3.142857142857143
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 49
Pinion Tooth Count: 13
Total Voltage: 14.8
Motor KV: 2300
Tire Diameter (inches): 4.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.77 : 1
Total Ratio: 11.84615 : 1
Tire Circumference (inches): 14.14 inches (359.08 mm)
Total Motor Speed: 34040 RPM
Vehicle Speed: 38.47 mph (61.79 km/h)
Estimated Adjusted Speed: 37 mph (59 km/h) - 5% loss
Effective KV Value: 2300
KT constant: 0.59 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
REAL MEN RUN BRUSHLESS
