E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.14.2008, 04:05 PM
Have you tried charging that low cell by itself through the balance taps? If you can bring it back up to 4.2 then see how it retains voltage after a run. The pack may not be a total loss, it may just have been assembled with a non-fully charged cell initially. Yes, that's MA's fault but it can be fixed. Do the same with the other, better balanced pack. I'd keep it to a 1A charge through the taps, and don't forget to set the charger to 1 cell. If it doesn't work out then I'll let MA handle it from here.
I have charged and discharged through the tap to get them even a few times, but everytime I run them they are way off again. MA has suggested using contact cleaner to amke sure they are 100% clean and use a volt meter instead of relying on the charger. I had already verified with a volt meter, the charger's readings are a bit off from my volt meter but are consistent, cells are off by equal amounts between volt meter and charger.
I heard back from Jason, he's the one that told me to take the previously mentioned steps. He said if that doesn't work to contact Alex at MA and he will tell me what to do.
