what's the best diff fluid weight for 8B/8T for racing and why?
Ryu James
Ryu James's Avatar
what's the best diff fluid weight for 8B/8T for racing and why? - 10.15.2008, 03:49 PM
what is the best diff fluid to run a race Losi 8 truggy? for center, front, and rear? and what effect does having light and heavy fluids have on performance?
Jammin SCRT10 Neu 1512 1y
10.15.2008, 05:25 PM
The term "best" is highly objective. This is a pretty good post about diffs in general.
stum
10.15.2008, 05:56 PM
In my 8ight-e Buggy I've got 7k 10k 3k and like it. I only race on dirt tracks with mine... no bashing at all. I just finished building my 8-e truggy and went with 7k 30k 3k. Typical nitro configs go w/ 20k center, but I have a TON more torque than any nitro setup w/ my Neu 1515 so I went 10k heavier. I won't be racing it until Saturday though.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.15.2008, 06:51 PM
7K / 10K / 3K seems to be the most common weight oil used in the 8B
jhautz
jhautz's Avatar
10.16.2008, 02:18 AM
You can adjust the characteristics of the differentials by using thinner or thicker silicone
oil within their cases.
• Changing the oil in the front differential affects overall steering response.
• Changing the oil in the center differential affects the front-to-rear drive.
• Changing the oil in the rear differential affects cornering traction and overall steering.
Front
Thinner
• Increases steering into corners (off-power)
• If oil is too thin the steering may become inconsistent,
especially it can lose forward traction (and steering)
during acceleration out of corners
Thicker
• Increases stability into corners during braking
• Increases steering on-power at corner exit
Center
Thinner
• Front wheels unload more during acceleration
• Decreases on-power steering (reduces oversteer)
• Easier to drive on rough tracks
• If a high-power engine is used you could waste too
much power and sometime “cook” the oil in the center
differential because it “overloads”
• More off-power steering
Thicker
• More all-wheel drive effect
• Better acceleration
• Increases on-power steering (reduces understeer)
• Better suited on high-bite, smooth tracks
• Car can be more nervous to drive especially if a high
power engine is used - you might need to be smooth on
the throttle
Rear
Thinner
• Increases cornering traction
Thicker
• Decreases rear traction while cornering
• Reduces wheelspin
to make it...
or break it...
Silent...But Deadly
Ryu James
Ryu James's Avatar
10.16.2008, 02:56 AM
this is all very helpful guys. thanks.
jayjay283
jayjay283's Avatar
10.18.2008, 12:17 AM
10/30/7 8T im thinkin i need 50k/w center though with a robinson wide 47p spur, heavy biotch
