Takedown
WARNING: May become violent.
Takedown's Avatar
10.22.2008, 11:38 AM
Im in "first" robotics for the first time this year because its the schools first year hosting it. Ive been in robotics programs before though such as "vex" and its very fun. It challenges your mechanical and electrical abilities to a very far extent.
As for the combo. Its not going to cut it if its maxing out the ESC like that if Im reading what you are saying correctly.
RIP- Tammy (9/14/08)
Fast5sRevo88
10.22.2008, 12:14 PM
Well the esc says for sure that it will run 140amps continous. The motor says that it will run at up to 150amps@48v continous, the way i'm reading, that seems to be the top end of the continous rating for the motor. Wouldn't running it at 60v instead of 48v reduce the amps?
Fast5sRevo88
10.22.2008, 12:56 PM
I found a performance chart for the Etek and the 150amp rating at 48v is full-tilt. The motor only draws about 75-80amps at peak efficency. The hp rating is 15horses at 150amps but the peak eff. is 8horses. Keep in mind its gonna be geared down via chain drive and it won't see large hill all that often.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.22.2008, 07:33 PM
Even then, it would need to be a very steep hill and you would need to be moving very fast up said hill to require all 15HP.
Fast5sRevo88
10.22.2008, 07:46 PM
That's i'm saying, but i would want to be sure how compatible this setup is before spending all that money.
Andrew32
10.22.2008, 01:07 PM
HEY! welcome. Iv been apart of FIRST for 6 years. 2 as a student of team 1002 and 2 as mentor for team 2415. What is your team number?
