I got both lipos in today, and had a good look at them
bb16: your lipo should be fine, so I will solder it back together and see how it does. I can run it in my slayer as a load test, then recharge it. What is the pack spec?
nitrodude: your pack has a puffed cell, so I have removed it. I will say that protek use some very nasty glue and plastic to fill the end of the pack that has all of the connections. It is like hot glue and some sort of expanding foam type glue. I have removed enough of it to get to the contacts. What kind of pack do you want? 2 2s packs or a single 4s?
As a note to everyone else, I am not fond of the protek packs, but will continue to fix them. All other packs have been pretty easy compared to the protek.
