DickyT
11.05.2008, 10:15 AM
Looks good Metal Man, now go get it dirty!
MetalMan
MetalMan's Avatar
11.05.2008, 02:24 PM
Originally Posted by Klausen View Post
I am about to convert my CRT1 as well. I will probably buy Mikes motormount and batterytray, and run it on 4s lipo and a 8XL. Can you tell me what pinion size I should go for?
First off, will you be running the stock spur gear or will you convert to the 46t spur gear (from the X1-CR buggy)? If you stay with the stock spur (62 teeth), an 18t pinion would work well. If you are running a 46t spur, the smallest pinion Mike's mount will let you use is 14t (mine is using 14t).
Hah, gotta receive my MMM V3 first . CC received my V2 last Friday.
DickyT
11.05.2008, 02:43 PM
Ditto... at least I have a spare MM to hold me over. i have not been bit by the HV bug yet..
