Hmm, at what point is Castle actually going to fix the fan wire issue so customers won't feel the need to open the case and check them? Or how about the bullet to heatsink spacing issue?
that was the exact reason I open the case...the wires looked so smashed I figured I could fix that and not have to send it back
seems like they could have used some sort of small grommet in this area
I agree. if thats true then thats BS. I dont care how muh better the case is, the fan will still eventually fail and when it needs to be replaced we have tosend it to castle? If thats the case then ultrasonically seal the case shut and be done with it. I dnont know how they could prove you opened the case anyway. Only if you mod something inside.
to make it...
or break it...
