mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
11.08.2008, 11:19 PM
Is that traxxas 2.4 radio even going to be available for purchase individually before chistmas?
I couldnt tell you anything about those servo's. Personally, I'd stick with the stock traxxas ones until you can afford to buy a single good one.
Also, If you are buying 4S batteries, you can ONLY run them in parrallel on the MMM - its only rated for 6S.
i hope the radio will release before otherwise i could try those glitch busters
i was thinking about staying stock but they cant be much worse than traxxas servos. better torque and speed. i want to save for a good single but i the 5955tg's are discontinued and replaced by the more expensive 7955tg and would need a programmer i think and an aluminum single arm. and as stated before im runnin them in parellel
-mikey09120
JThiessen
JThiessen's Avatar
11.08.2008, 11:32 PM
Yeah, so why spend the money on these...at 19 bucks each, I can almost guarantee that they are not going to last, and highly doubt you will gain anything over the stockers. The single biggest issue people have with the stock ones is that they can get out of time, and work against each other. IHMO, you will only waste 30% of the money you could use for a single servo.
You dont have to purchase anything more than the servo to run it. You can just trim the unused arm off (or just leave it). You dont need the programming kit either - thats for flyers.
I'd listen to the other guys on the batteries....I think you might have a hard time fitting 4S in the tray. My brother in law has the 4S 4900 Zippy's, and if I get the chance, I'll see if they fit in the tray on the chassis I have.
mikey09120
mikey09120's Avatar
11.08.2008, 11:44 PM
if the servos dont work then oh well. back to stock. if they do then people have cheap replacements. and the batts are 140x30x49 so they fit fine. if they lied oh well. i can sell them or mod the trays
-mikey09120
mikey09120
mikey09120's Avatar
11.09.2008, 12:53 AM
any ideas for chargers. really cheap with balancing or a seperate balancer
how bout the first one in this page
and the second on this page
-mikey09120
